is it possible to use TPM at 2x clock
1,494件の閲覧回数
tuomasaaltio
is it possible to use TPM from 48MHz clock and system and bus clock 24 MHz?  Device KL25Z128VLK.
1,429件の閲覧回数
kerryzhou
Hi tomas aaltio,
    You can find the TPM clock source from the reference manual:
So, You can choose PEE mode, then use MCGPLLCLK, then your TPM clock will be 48Mhz.
Just like this :
Wish it helps you!
If you still have question, please let me know!
Kerry
