how many times can i programming a MKL16Z256VLH4?
1,977件の閲覧回数
omarmendiola
hi, someone knows, how many times can i programming a MKL16Z256VLH4? or what is its life time?
タグ(2)
3 返答(返信)
1,825件の閲覧回数
kerryzhou
Hi omar mendiola,
   SCOTT MILLER is correct. Please refer to the KL16 datasheet.
Wish it helps you!
If you still have question, please let me know!
Kerry
1,825件の閲覧回数
scottm
Senior Contributor II
The data sheet (3.4.1.4) says it's rated at a minimum of 10,000 cycles, and typical is 50,000 cycles.  Engineering bulletin EB619 has more details.
Scott
1,825件の閲覧回数
omarmendiola
