eGUI with SSD1325 OLED Controller?
4,033件の閲覧回数
anguel
Contributor V
Hi!
I wonder if it will be possible to use eGUI with the Solomon Systech SSD1325 OLED controller:
http://www.newhavendisplay.com/app_notes/SSD1325.pdf
If yes, will it be hard to adapt for example the existing SSD1289 driver to this controller?
Thank you for any hints!
Anguel
タグ(3)
6 返答(返信)
3,317件の閲覧回数
apanecatl
Senior Contributor II
Hi Anguel, th eGUI software has been exclusively designed to work with Freescale silicon, I'm afraid you CANNOT use it with any other semiconductor brand products or you might face legal issues due to infringement. I apologize for this but our software enablements are aimed to help our customers make a better use of our products.
3,317件の閲覧回数
anguel
Contributor V
I AM using Freescale, this is a display controller I want to interface...
3,317件の閲覧回数
apanecatl
In that case, the eGUI tool provides a generic template configuration example, you can find it in the D4D folder. If you cannot find it in the folder, it is attached to this post.
3,317件の閲覧回数
anguel
Contributor V
Thanks for the hint but I already know about these files.
I am not sure if it is possible to drive grayscale displays with eGUI? The manual does not mention anything about that.
3,317件の閲覧回数
apanecatl
Yes, the K70 LCDC module can drive grayscale displays as depicted in page 2183 of the device's reference manual.
3,317件の閲覧回数
anguel
Contributor V
And how is this related to eGUI???
