d4dlcdhw_template_ID
1,958件の閲覧回数
ankurchauhan123
I'm using TWR-K70 kit with TWR-LCD module.
I'm trying to use D4D libraries.
I'm getting the following error:
Undefined Reference to d4dlcdhw_template_ID
in the following line :
D4D_LLD_LCD_HW.D4DLCDHW_WriteData(win_cur_addr, value);
what could be the resaon???
Ankur
タグ(1)
2 返答(返信)
1,904件の閲覧回数
LuisCasado
What IDE are you using? You have a working project here: https://github.com/Gargy007/eGUI
If the IDE is different, be sure you're using the right configuration of the library (low level drivers).
Luis
1,904件の閲覧回数
ankurchauhan
Hi Luis,
Thanks for reply.
I'm using CW 10.6.4
