conversion from 'unsigned int' to 'U16' {aka 'short unsigned int'} changes value from '2089472' to '
AsafTv
#define FLASH_STORAGE_SIZE        (0x1000000)
#define FLASH_STORAGE_SECTOR_SIZE        (0x1000)
#define FLASH_STORAGE_BOOT_ADDRESS        (0x000000)
#define FLASH_STORAGE_BOOT_SIZE        (0xD000)
#define FLASH_DEVICE_INFO_ADDRESS        (FLASH_STORAGE_SIZE - 2 * FLASH_STORAGE_SECTOR_SIZE)
#define FLASH_NEW_IMAGE_FILE_INFO_ADDRESS        (FLASH_STORAGE_SIZE - FLASH_STORAGE_SECTOR_SIZE)
#define FLASH_STORAGE_CURRENT_FIRMWARE_SIZE        ((FLASH_STORAGE_SIZE - (2 * FLASH_STORAGE_SECTOR_SIZE + FLASH_STORAGE_BOOT_SIZE)) / 2)
i get this warning on  FLASH_STORAGE_CURRENT_FIRMWARE_SIZE
What I'm doing wrong?
ErichStyger
Specialist I
The problem is how you *use* this macro, so you have to check where (and how) it is used.
But basically it looks your are truncating the bits to unsigned 16bit.
