Which port have internall pullup or down on MK60FN1M0VLQ12 ?
1,373件の閲覧回数
fabriceeichenbe
hello,
I can't find which port have internall pullup or down on MK60FN1M0VLQ12.
I read the chapter signal multiplexing and signal description of K60 Sub-Family Reference Manual Rev. 3, November 2014 but it doesn't seem to be here.
Does anyone know where this information is ?
Yours faithfully
Fabrice Eichenberger
タグ(1)
1,312件の閲覧回数
egoodii
Senior Contributor III
I have always considered the 'lack of information to the contrary' to indicate that ALL GPIO pins have full port-control-options, including pull-enable and pull-direction.  This is in contrast, for instance, with the K22P121M100SF9RM.pdf table 10-2, that lists 'GPIO limitations' for that part, although even in THAT case pull-enable and pull-direction are available on all ports/pins.
1,312件の閲覧回数
fabriceeichenbe
OK, thank you :smileyhappy:
