What is the effective no. of bits in 12 bit ADC present in K20 uc?
1,442件の閲覧回数
Amit_Kumar1
Senior Contributor II
I wanted to know what is the effective no. of bits with and without noise in 12 bit and 14 bit ADC present in k20 uc? and is there any document which states these values for kinetis ucs so that I can select the desired uc according to the appliation requirements.
Thanks & Regards
Amit Kumar
タグ(4)
3 返答(返信)
1,211件の閲覧回数
Paul_Tian
Hi, Amit Kumar
You can find the effective bit nunber in datasheet. ENOB is the parameter you need. You can search it in datasheet.
Best Regards
Paul
1,211件の閲覧回数
Amit_Kumar1
Hi Tian
In datasheet ENOB is given for 16 bit ADC only I need to know for 12 bit also
regards,
Amit
1,211件の閲覧回数
Paul_Tian
Hi, Amit
I checked other MCU which has 12-bit ADC. There is not ENOB. So I think you can use quantization error directly and no need to care ENOB.
Hope my reply can help you.
Best Regards
Paul
