The Kinetis family is based on Cortex-M4 controller. Certain devices of Kinetis product family with cortex-M4 provides single precision floating point unit.
How can I leverage and make use of floating point unit in my application for efficient floating point operations? Do compiler take care of making use of floating point unit?
Any suggestions/Hints/links/application notes will be helpful.
Thank you,
d2v0
I use Keil MDK-ARM V4.20.
file--Device Database...
Find Freescale Semiconductor--MK60X256VMD100 and double click;
At "Options:" area, you can find "CPU=IRAM(0x1FFF8000-0x1FFFFFFF) IRAM2(0x20000000-0x20007FFF) IROM(0x0-0x3FFFF) IROM2(0x10000000-0x1003FFFF) CLOCK(12000000) CPUTYPE("Cortex-M4") ESEL ELITTLE"
Add "FPU2" at the end of this line,Then it become "CPU=IRAM(0x1FFF8000-0x1FFFFFFF) IRAM2(0x20000000-0x20007FFF) IROM(0x0-0x3FFFF) IROM2(0x10000000-0x1003FFFF) CLOCK(12000000) CPUTYPE("Cortex-M4") ESEL ELITTLE FPU2"
click "Update", close.(You may create a new device,with the copy of k60)
Then create a new project, select Freescale Semiconductor--MK60X256VMD100(have been changed ) .
It can generate FPU code when use floating point arithmetic in your C program.(You should enable the FPU first,if not it will hard fault).
Project--Options for Target 'Target1'..., at "Target" table,you can find "Use FPU" as default.
How to enable the FPU ?
ADD the code below in your startup.s
My test:
1.head.s
IMPORT main AREA startup,CODE THUMB DCD 0x20000000 DCD resetreset PROC ENTRY ; CPACR is located at address 0xE000ED88 LDR.W R0, =0xE000ED88 ; Read CPACR LDR R1, [R0] ; Set bits 20-23 to enable CP10 and CP11 coprocessors ORR R1, R1, #(0xF << 20) ; Write back the modified value to the CPACR STR R1, [R0] push {r0-r1} LDR R0,=main BL main B . ENDP ALIGN END
2,main.c
int main(){ float a=1.0098; float b=1.9987; float c; c=a*b; return (int)c;}
the *.sct
ROMLOAD 0x0 0x4000{ EXEC_RO 0x0 { head.o(startup, +first) *(+RO) } RAM 0x1FFF8000 { *(+RW,+ZI) }}
result:
3: float a=1.0098; 0x00000028 EDDF1A08 VLDR s3,[pc,#0x20]0x0000002C EEB00A61 VMOV.F32 s0,s3 4: float b=1.9987; 5: float c; 0x00000030 EDDF1A07 VLDR s3,[pc,#0x1C]0x00000034 EEF00A61 VMOV.F32 s1,s3 6: c=a*b; 0x00000038 EE601A20 VMUL.F32 s3,s0,s10x0000003C EEB01A61 VMOV.F32 s2,s3 7: return (int)c; 0x00000040 EEFD1AC1 VCVT.S32.F32 s3,s20x00000044 EE110A90 VMOV r0,s3
If I not use the fpu,the result is:
3: float a=1.0098; 0x0000002A 4806 LDR r0,[pc,#24] ; @0x000000440x0000002C 4604 MOV r4,r0 4: float b=1.9987; 5: float c; 0x0000002E 4806 LDR r0,[pc,#24] ; @0x000000480x00000030 4605 MOV r5,r0 6: c=a*b; 0x00000032 4629 MOV r1,r50x00000034 4620 MOV r0,r40x00000036 F000F825 BL.W _fmul (0x00000084)0x0000003A 4606 MOV r6,r0 7: return (int)c; 0x0000003C 4630 MOV r0,r60x0000003E F000F805 BL.W _ffix (0x0000004C)
Where do I insert the code in the startup.s? I have the startup_MK60N512MD100.s which is different from your example:
The scatter-file is also different:
Thank you for the informaiton. I will try as you said.
