Unused USB Pin configuration in MK60DN512VLQ10
nbjasani
    I'm creating a design with MK60DN512VLQ10 device for Power electronics control application. In that design i am not using USB Functionality.
    What should i do with following pins, whom i can avoid EMI. Should i kept open?
1. VREGIN         -Pin No.22
2. VOUT33         -Pin No.21
3. USB0_DP       -Pin No.19
4. USB0_DM      -Pin No.20
Thanks in Advance
Nandish Jasani.
Omar_Anguiano
Hello Nandish Jasani
Thank you for your interest in NXP Semiconductor products and the opportunity to serve you.
This post might be useful Configuration for Unused Pins/GPIOs on Kinetis
Let me know if this is helpful, if you have more questions do not hesitate to ask me.
Omar
bobpaddock
Senior Contributor III
Does that apply to the USB Regulator input, VREGIN?
Omar_Anguiano
Hello Bob Paddock
Yes, the configuration discussed in the post also applies to VREGIN.
Omar
nbjasani
Thanks Omar Anguiano,
       I read that post, it really very useful for hardware design,
Nandish Jasani.
