USB device Bus Turnaround Timeout
ソリューションへジャンプ
8,336件の閲覧回数
martindusek
Contributor V
I adapted USB stack HID device example and made USB generic HID device. Unfortunately, I receive bus turnaround timeout error during enumeration after Device descriptor is sent. The consequence is that Windows doesn't recognize my device.
Can you please advise anything?
Martin
タグ(4)
5,972件の閲覧回数
martindusek
Contributor V
The issue has been solved - we forget to add 2u2 capacitor to VOUT33 pin. Therefore the output of the regulator was unstable.
2 返答(返信)
5,972件の閲覧回数
DerekLau
If you have modified the example, please check the descriptors that you have modified.
If you haven't, please tell us what is the version of USB stack HID example and what device you are using.
5,972件の閲覧回数
martindusek
Contributor V
