Trying to load an OpenSDA Application
1,110 次查看
blazerogers
Im working with the kl02. when I try to copy/paste the file (MSD-FRDM- KL02Z_v108_Pemicro.SDA)to the boot loader then unplug/plug the usb in I can't get the FRDM-KL02Z drive to show up. Any suggestions would help.
标记 (4)
973 次查看
kerryzhou
Hi blaze rogers,
    As I know, macbook with os X YOSEMITE  is not ok, you should better use the computer with  Window 7 os.
    If you use Window 8, you should follow the first FAQ from PEmicro opensda, the link is :
http://www.pemicro.com/opensda/faqs/faqs.cfm
Wish it helps you!
Jingjing
973 次查看
yasuhikokoumoto
Senior Contributor I
I guess you did the procedures on Windows8.x.
The bootloader update of OpenSDAv1 will fail on Windows8.x.
You should do them on Windows7.
Yasuhiko Koumoto.
973 次查看
blazerogers
And what about on a macbook pro with os x yosemite?
974 次查看
kerryzhou
Hi blaze rogers,
Wish it helps you!
Jingjing
