Timers of less than 1 ms
已解决
跳至解决方案
3,035 次查看
feraro
Hello.
How could obtain Timers less than 1 millisecond and MQX TWR60N512 7.1?.
1 解答
2,680 次查看
konrada
You can use the PIT, programmable interval timer.
在原帖中查看解决方案
4 回复数
2,681 次查看
konrada
2,680 次查看
feraro
Thank you very much for the idea, but I'm new to MQX and can not understand how to use a PIT. What I need is to create a pulse train by pin PORTE PIN10 of 0.1 msec period.
Thanks for everything.
2,680 次查看
konrada
If you want to toggle an output pin that fast, try the FTM, which does PWM.
The Reference Manual for your chip will tell you if port E10 can be connected to some FTM channel. If not, you can toggle a GPIO pin in software from a PIT interrupt, but that incurs jitter.
2,680 次查看
feraro
Hey.
I've definitely got it working with the PIT.
Thank you very much for everything.
