The MKW40Z reset waveform is strange.
2,160 次查看
minjaekim
I maked the board with MKW40Z
but, reset signal is strange
do you know what's matter?
标记 (2)
2,135 次查看
gerardo_rodriguez
Hello Minjae,
On blank chips, this is the expected behavior  because the MCU keeps resetting as it is loading an invalid address to the stack pointer and program counter. Once flashed, the reset should stop oscillating.
