The JTAG/SWD is disabled and the program cannot be downloaded
2,075 次查看
qzy_perfect
The JTAG/SWD is disabled and the program cannot be downloaded.
3 回复数
1,926 次查看
qzy_perfect
Hi everyone,
   Thanks for your attentions. Now my board can work again under a warm - hearted man's great answer, as the following websit.
When i connect TWR-KE18F to my PC it shows portal device instead of COM PORT. I unable to change boo...
    Your kindly attention  is enough to warm a world. Have a good day and wish you good luck.
   qzy
1,926 次查看
miduo
I am pretty sure that this is a same post with another one submit by you? We will disscuss it with that case. Thanks.
1,926 次查看
qzy_perfect
Yes, the another one is submit by me. Thanks for your attention.
