TWR-LCD-RGB
TWR-LCD-RGB
766 次查看
alonrozenfeld
hello,
we got a TWR-K70F120M + TWR-LCD-RGB, all the set,  using Kinetis Design Studio 3.0.0 IDE.
I added LCDC_LDD componnent, configuried pins of RGB and V/H sync, added code from help "typicla use", but every time that code tried to use PutPixel(x, y, c); it throwing to ISR
PE_ISR(Cpu_ivINT_Hard_Fault)
  /* This code can be changed using the CPU component property "Build Options / Unhandled int code" */
  PE_DEBUGHALT();
this is the code:
void main(void)
  /* Write your local variable definition here */
  LDD_TDeviceData* dd;
  LDD_LCDC_TBitmap bitmapInfo;
  LDD_LCDC_TWindow windowInfo;
  /*** Processor Expert internal initialization. DON'T REMOVE THIS CODE!!! ***/
  PE_low_level_init();
  /*** End of Processor Expert internal initialization.                    ***/
  /* Setup drawing variables for buffer */
  bitmapAddress = LCD_START_ADDRESS;
  bitmapWidth = LCD_RES_X;
  bitmapHeight = LCD_RES_Y;
  /* Clear buffer - red color */
ClearScreen(63, 0, 0);
  /* ... draw some primitives or load image data ... */
  dd =  LCD_Init(NULL);
  /* Fill bitmap information */
  bitmapInfo.Address = (LDD_TData*)bitmapAddress;
  bitmapInfo.Width = bitmapWidth;
  bitmapInfo.Height = bitmapHeight;
  /* Fill window information */
  windowInfo.X = 0;
  windowInfo.Y = 0;
  windowInfo.Width = bitmapWidth;
  windowInfo.Height = bitmapHeight;
  /* Initialize background plane 0 */
  LCD_SetupBitmap(dd, LDD_LCDC_PLANE_0, &bitmapInfo);
  LCD_SetupWindow(dd, LDD_LCDC_PLANE_0, &windowInfo);
  LCD_SetupWindowPosOnScreen(dd, LDD_LCDC_PLANE_0, 0, 0);
  /* Enable LCD */
  LCD_Enable(dd);
  for(;;) { }
what do I miss?
as I understood there are no examples for KDS.
is there any demo app that I can boot to mk70 to see something on the screen, the screen is always white, like there is no signal to it.
please help, thank you!
474 次查看
Carlos_Mendoza
Hi Alon,
As you mention there are no examples for KDS using TWR-LCD-RGB but you could use the eGUI demo application for the TWR-K70F120M board fusing the TWR-LCD-RGB, you can find more information on this link:
Getting started with the eGUI (a.k.a. D4D)
Hope it helps!
Carlos Mendoza
Technical Support Engineer
