TWR-K60N512 MQX Web eample IAR project not compiling
2,998 次查看
tkotze
Hi there, I am new to IAR, Freescale and MQX, but that should not be a problem, since Freescale provided me with enough sample proects to get going. However, I am trying to compile the MQX web project form the quick start demo, and it keeps telling me that there are problems with the project.
When I click on the eww project file, IAR starts but gives me an error saying that "Broken options were detected in the project file". When I click on OK, it tells me that an unknown tool has been found, "PEMICRO_ID", then tessl me and invalid driver option exists, invalid processor option exists, "no kernel to load" and that an "error occured while trying to initialize debugger".
I looked at the basics, selected a processor in the options, checked to see if MQX was installed (it is). I am at a lost here and would prreciate any help.
Thanx
1 回复
2,315 次查看
Jaux
MQX and CodeWarrior is not supported on the K60 - you have to use the IAR IDE.
