TWR-K40D100M with TWR-MC-LV3PH
979 次查看
filip_p
I was given these modules:
TWR-K40D100M ,
TWR-ELEV and
TWR-MC-LV3PH and
motor 45ZWN24-40.
My question is is it possible to make this motor run with these modules? If it's possible, are there any application or suite to make this work?
Thanks in advance
925 次查看
xiangjun_rong
Hi, Filip,
Pls refer to the link:
3-Phase Brushless DC Motor Control Design|NXP
and download the "software for 3-Phase Brushless DC(BLDC) Motor Control" package.
after you unzip it, you can see that it only supports TWRKV10/11/31/46/58, it does not support TWR-K40D100 board.
But you can check the code and port it to TWR-K40100D yourself.
Hope it can help you
xiangjun rong
