TCP Client
TCP Client
jill1
hello,
I'm trying to implement a client code using netconn. It's working but I can't use the same port twice. When I compile the code for the first time the connection works fine. But the second I get retransmissions. I think I have to close/free the port from my server (linux netcat server) somehow. I already close, disconnect and delete my netconn socket.
Thanks for your help.
Jill
danielchen
Hi Jill:
Could you please let me know how to reproduce your issue on my side? Your hardware and software, or a simple project  for me to reproduce it?  Thanks
danielchen
Because there's an active TCP connection on that port. The client and server  are still tring to gracefully close the connection.
I tried on my side with force-close the connection with "netconn_close"  + "netconn_delete",  I can get the right result.
