Speed Control Filtering
1,123件の閲覧回数
CMooN
I read this document. https://community.nxp.com/t5/Model-Based-Design-Toolbox-MBDT/Module-8-Speed-Control/m-p/727476
I could not understand how to filter the speed in my project ?
Which techniques should I use ?
Thank you...
1,104件の閲覧回数
_Leo_
Thank you so much for your interest in our products and for using our community.
In the document you mention, as such the speed is not being filtered, since for this a large number of samples are required and this involves delays in the closed control loop, which can create instability in the system.
What is described in the document are two ways to calculate speed:
The first one is based on Hall sensor transitions (Equation 1). However, this presents variations.
The second is based on one hall signal transitions (Equation 2 and Fig. 12).
You can also download the Simulink model at the end of the document for more detail.
Hope it helps you. Please let me know if you have more questions about it.
Have a nice day!
