SDHC Interface regarding.
yasararafath
I am having the SDHC interface driver with the MQX OS layer for Kinetis K40.
I need the bare board project code for SDHC interface for same controller without any OS.
If anyone has please send me to my mail [email protected] or send the link.
Thanking You,
-Yasar Arafath
Hui_Ma
Please check attached example code about Kinetis ESDHC module.
Wish it helps.
B.R.
Ma Hui
Hui_Ma
Wish it helps.
B.R.
Ma Hui
yasararafath
Friend,
Found your code and it detects the card and initializes.
Another one question in that code  the address given is 0x1FFFFA000, that is the address of SRAM.
Then how to mention the address of the external card.
Waiting for your reply.
yasararafath
Friend,
Thank you very much for the reply.
Does it suits all type of cards?
I am using full SD(4GB). Verify the spec of the card here.
http://www.flipkart.com/sandisk-sdhc-4gb-memory-card/p/itmczcrqbsrzrrga
In the meanwhile I also try to implement whichever you given.
-Yasar Arafath
