S9KEAZN16 LIN communication project example
927 次查看
cg0
Hello I use S9KEAZN16 as a sensor controller, and we need LIN communication, the sensor is slave node, I want to find an example, but it seems that S32DS have no example. So I want if can give me one or two examples. one is bare project without LIN stack layer. if have LIN stack, the orther one with LIN stack layer.
Thank you very much.
标记 (3)
834 次查看
kerryzhou
Hi Aron Cheng ,
  About the S9KEAZN16 LIN examples, you can refer to the LIN stack:
https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=SW-LIN2X-J2602-D
Please try it on your side.
If you still have questions about it, please kindly let me know.
Kerry
