S9KEAZ128 power sequence
1,287 次查看
wenfengyao
hello,When I was using S9KEAZ128, I found the following boot sequence in RM
For this chip, where can I find the timing requirements for power-on, crystal vibration, rst pull-up, etc?
1,273 次查看
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, let me get into your case and when I have more information, I will contact you.
Pavel
