Request FRDM KE06Z dimensions
ソリューションへジャンプ
2,608件の閲覧回数
MKuserH
Greatings,
I couldn't found a board layout of FRDM KE06Z and I wanted the dimensions with the positions of the holes, etc in order to a shield for this board. If anyone can post the gerber o a simple schematic with the positions of the holes, It will help.
thanks.
2,593件の閲覧回数
RaRo
Hello @MKuserH,
Please check the following document: FRDM-KE06Z.pdf, hope it helps you.
Also, you can check the schematic here: FRDM-KE06Z|Freedom Development Platform|Kinetis® MCU | NXP Semiconductors in Design Resources.
Best regards, Raul.
2 返答(返信)
2,594件の閲覧回数
RaRo
Hello @MKuserH,
Best regards, Raul.
2,587件の閲覧回数
MKuserH
Hi @RaRo ,
Thanks for your reply. It's a great help but I need to know in which position of X and Y are the holes for the CANBUS.
Best regards, MK.
