Reference Documentation for MQX for ARM Cortex
已解决
跳至解决方案
3,377 次查看
BenG
This may be a silly question but the main site seems to hide information away and makes it a little hard to find.
Where is the documentation/reference manual for the  MQX for ARM Cortex library/functions.
E.g.. The documentation for functions like:
_int_install_isr()
_cortex_int_init()
I'm sure it must be somewhere, I just can' find it.
1 解答
3,195 次查看
J2MEJediMaster
Specialist I
You might want to ask this question in our MQX forum. It's pretty active and someone may have an answer for you there.
---Tom
在原帖中查看解决方案
4 回复数
3,195 次查看
c0170
Senior Contributor III
Hi BenG,
there is only referance manual for MQX RTOS where are described functions and macros, not for platform as for kinetis/arm.
If you want more detailed description, you have to dig into the code.
MartinK
3,195 次查看
BenG
Oh dear, that's not very good :-o
3,195 次查看
J2MEJediMaster
Specialist I
---Tom
3,195 次查看
BenG
---Tom
Cheers Tom,
I will do.
