Reduce memory footprints in mbedtls
pritesh_shah
I want to reduce the memory footprint of mbedtls library. I found the below link to optimize the mbedtls.
https://tls.mbed.org/kb/how-to/reduce-mbedtls-memory-and-storage-footprint
In this document one of the option is to save memory is to use mbedtls_x509_crt_parse_der_nocopy() function
instead of mbedtls_x509_crt_parse_der().
I have downloaded an SDK for Kinetis K64 and in that, i didn't found the mbedtls_x509_crt_parse_der_nocopy() function in mbedtls.
Is there any upgrade in the package ? How can i reduce the memory footprints for mbedtls. ?
Tags (2)
kerryzhou
Hi Pritesh shah ,
  From the kinetis SDK x509_crt.c , this frile is part of mebd TSL(SSL Library mbed TLS / PolarSSL ).
  So, if you want to get the mbedtls_x509_crt_parse_der_nocopy() API, you may go the mbed side, find the newest driver which contains mbedtls_x509_crt_parse_der_nocopy() api function, and copy it to the SDK code.
  The newest SDK still didn't add the API which you mentione, but I think you can add it by yoursefl.
Wish it helps you!
Kerry
