RTOS that can be used for KEA128
2,598 次查看
jashanm
Hi all,
        I am working with KEA128 for some time, right now i need to work this with any RTOS. So which RTOS does the KEA128 works well ?
Jashan M
2,430 次查看
ivadorazinova
Hi Jashan!
You can try MQX™ Lite RTOS​ or AutosarMCAL​.
Hope this helps.
Iva
2,431 次查看
ivadorazinova
Hi Jashan!
Hope this helps.
Iva
2,430 次查看
jashanm
Hi Iva,
         Can i use CW to implement the MQX Lite RTOS ? and how different is it from the normal work (from programming structure end) ?
Jashan M
2,430 次查看
ivadorazinova
Hello Jashan.
Yes, it is part of CW - it is included in CW folder.
You can find it under features in CW folder.
Please, take a look at User Guide and Reference Manual for MQXLite.
C:\Freescale\<CW_installation_package>\MCU\Help\PDF\MQXLite_User_Guide.pdf
C:\Freescale\<CW_installation_package>\MCU\Help\PDF\MQXLite_RM.pdf
I hope this helps.
Iva
