RADE Error (Code 1) on KW47B42Z83AFTB — digital_key_car_anchor_cs_freertos
655件の閲覧回数
chris123951
 Hi NXP Support Team,
We are using the KW47B42Z83AFTB on a custom PCB for both ECU (anchor/car side) and Transponder (device side) roles.
Setup:
- SDK: SDK_25_12_00_KW47B42Z83xxxA
- ECU (Initiator / Car Anchor): flashed with digital_key_car_anchor_cs_freertos
- Transponder (Reflector / Device): flashed with digital_key_device_cs_freertos
- Both devices are on the custom PCB design
Issue:
On the initiator side (ECU / car anchor), we consistently receive RADE error code 1 during Channel Sounding procedures. RTT distance measurement runs correctly on both sides, but the RADE-based distance calculation fails at the initiator.
Questions:
1. Is RADE distance calculation supported on KW47B42Z83AFTB (no LCE) with the current SDK?
2. Does error code 1 indicate that LCE hardware is required but absent, or is there a software fallback available?
3. Are there any known configuration flags in app_preinclude.h or the CS profile layer that need to be set for RADE on a non-LCE variant?
Please let us know if additional logs or configuration files would be helpful.
Christian
BLE-NFC  BLUETOOTH-BEACON
631件の閲覧回数
Ricardo_Zamora
Hope you are doing well. Is there any particular reason to use an IC version without LCE.
Anyways, I would recommend you checking this section from the SDK documentation: Enabling RADE v1 Usage (non-LCE) — MCUXpresso SDK Documentation
Ricardo
%3CLINGO-SUB%20id%3D%22lingo-sub-2362466%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKW47B42Z83AFTB%E3%81%A7RADE%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%88%E3%82%B3%E3%83%BC%E3%83%891%EF%BC%89%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%E2%80%94%20digital_key_car_anchor_cs_freertos%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2362466%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AE%E7%9A%86%E6%A7%98%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E7%A4%BE%E3%81%A7%E3%81%AF%E3%80%81ECU%EF%BC%88%E3%82%A2%E3%83%B3%E3%82%AB%E3%83%BC%EF%BC%8F%E8%BB%8A%E4%B8%A1%E5%81%B4%EF%BC%89%E3%81%A8%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%B3%E3%83%80%EF%BC%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E5%81%B4%EF%BC%89%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AE%E5%BD%B9%E5%89%B2%E3%81%AB%E3%80%81%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E5%9F%BA%E6%9D%BF%E4%B8%8A%E3%81%A7%3CSTRONG%3EKW47B42Z83AFTB%E3%82%92%3C%2FSTRONG%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%A8%AD%E5%AE%9A%EF%BC%9A%3CBR%20%2F%3E%20-%20SDK%3A%20%3CSTRONG%3ESDK_25_12_00_KW47B42Z83xxxA%3C%2FSTRONG%3E%3CBR%20%2F%3E%20-%20ECU%EF%BC%88%E3%82%A4%E3%83%8B%E3%82%B7%E3%82%A8%E3%83%BC%E3%82%BF%EF%BC%8F%E3%82%AB%E3%83%BC%E3%82%A2%E3%83%B3%E3%82%AB%E3%83%BC%EF%BC%89%EF%BC%9A%20%3CSTRONG%3Edigital_key_car_anchor_cs_freertos%3C%2FSTRONG%3E%E3%81%A7%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%B8%88%E3%81%BF%3CBR%20%2F%3E-%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9D%E3%83%B3%E3%83%80%EF%BC%88%E3%83%AA%E3%83%95%E3%83%AC%E3%82%AF%E3%82%BF%E3%83%BC%2F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%EF%BC%89%EF%BC%9A%20%3CSTRONG%3Edigital_key_device_cs_freertos%3C%2FSTRONG%3E%E3%81%A7%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%B8%88%E3%81%BF%3CBR%20%2F%3E-%20%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0PCB%E8%A8%AD%E8%A8%88%E3%82%92%E6%8E%A1%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%EF%BC%9A%3CBR%20%2F%3E%E3%82%A4%E3%83%8B%E3%82%B7%E3%82%A8%E3%83%BC%E3%82%BF%E5%81%B4%EF%BC%88ECU%EF%BC%8F%E8%BB%8A%E4%B8%A1%E3%82%A2%E3%83%B3%E3%82%AB%E3%83%BC%EF%BC%89%E3%81%A7%E3%81%AF%E3%80%81%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E6%89%8B%E9%A0%86%E4%B8%AD%E3%81%AB%3CSTRONG%3E%3CEM%3ERADE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%B3%E3%83%BC%E3%83%891%E3%81%8C%3C%2FEM%3E%3C%2FSTRONG%3E%E7%B6%99%E7%B6%9A%E7%9A%84%E3%81%AB%E5%8F%97%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82RTT%E8%B7%9D%E9%9B%A2%E6%B8%AC%E5%AE%9A%E3%81%AF%E4%B8%A1%E5%81%B4%E3%81%A7%E6%AD%A3%E3%81%97%E3%81%8F%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81RADE%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E8%B7%9D%E9%9B%A2%E8%A8%88%E7%AE%97%E3%81%AF%E3%82%A4%E3%83%8B%E3%82%B7%E3%82%A8%E3%83%BC%E3%82%BF%E5%81%B4%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%B3%AA%E5%95%8F%3A%3CBR%20%2F%3E%201.%E7%8F%BE%E5%9C%A8%E3%81%AESDK%E3%81%A7%E3%81%AF%E3%80%81KW47B42Z83AFTB%EF%BC%88%20%3CSTRONG%3ELCE%E3%81%AA%E3%81%97%3C%2FSTRONG%3E%EF%BC%89%E3%81%A7RADE%E8%B7%9D%E9%9B%A2%E8%A8%88%E7%AE%97%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%202.%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%B3%E3%83%BC%E3%83%891%E3%81%AF%E3%80%81LCE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%82%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%82%88%E3%82%8B%E4%BB%A3%E6%9B%BF%E6%89%8B%E6%AE%B5%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%203.%20app_preinclude.h%20%E3%81%AB%E3%81%AF%E6%97%A2%E7%9F%A5%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%83%95%E3%83%A9%E3%82%B0%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E3%80%81%E9%9D%9ELCE%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%E3%81%A7RADE%E7%94%A8%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8BCS%E3%83%97%E3%83%AD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%84%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%AD%E3%83%AA%E3%82%B9%E3%83%88%E6%95%99%E5%BE%92%3CBR%20%2F%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FBLE-NFC%2Fpd-p%2FBLE-NFC%22%20class%3D%22lia-product-mention%22%20data-product%3D%222717-1%22%20target%3D%22_blank%22%3EBLE-NFC%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FBLUETOOTH-BEACON%2Fpd-p%2FBLUETOOTH-BEACON%22%20class%3D%22lia-product-mention%22%20data-product%3D%222575-1%22%20target%3D%22_blank%22%3E%EF%BC%88%E3%83%96%E3%83%AB%E3%83%BC%E3%83%88%E3%82%A5%E3%83%BC%E3%82%B9%E3%83%93%E3%83%BC%E3%82%B3%E3%83%B3%EF%BC%89%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2362577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RADE%20Error%20(Code%201)%20on%20KW47B42Z83AFTB%20%E2%80%94%20digital_key_car_anchor_cs_freertos%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2362577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%AA%BF%E5%AD%90%E3%81%8C%E8%89%AF%E3%81%84%E3%81%A8%E3%81%84%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%82LCE%E3%81%AA%E3%81%97%E3%81%AEIC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E7%89%B9%E5%88%A5%E3%81%AA%E7%90%86%E7%94%B1%E3%81%AF%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E3%81%84%E3%81%9A%E3%82%8C%E3%81%AB%E3%81%97%E3%81%A6%E3%82%82%E3%80%81SDK%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E3%81%93%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fmcuxsdk%2Flatest%2Fhtml%2Fmiddleware%2Fwireless%2Fbluetooth%2Fdoc%2FBluetooth%2520Low%2520Energy%2520Localization%2520Application%2520Note%2Ftopics%2Fdisabling_lce.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%80%8CRADE%20v1%E4%BD%BF%E7%94%A8%E3%81%AE%E6%9C%89%E5%8A%B9%E5%8C%96%EF%BC%88%E9%9D%9ELCE%EF%BC%89%E2%80%94%20MCUXpresso%20SDK%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%80%8D%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%AA%E3%82%AB%E3%83%AB%E3%83%89%3C%2FP%3E%3C%2FLINGO-BODY%3E
