Problems reading Data from an FPGA via Flexbus
ChristofAbt
Good afternoon community, I try to read dta from an FPGA via the NXP Flexbus. The microcontroller is a MK66FN2M0VMD18. Address and Data are multiplexed on a 16bit bidirectional bus. The configuration is  defined in FB_Device0_config. The definition can be seen in the attached file peripherals.c I included
wait states there but to no avail. The C-Code I want to read the data looks like that.
lsb_ad7779_u16 = *(volatile uint16_t*)(fb_base->CS[0].CSAR +129);
It is a read access to address 0d129 = 0x81.
I can observe the data inside the FPGA with an internal logic analyzer. The Address, data and
control signals are as expected for a flexbus read access. Unfortunately I do not see
the correct data in lsb_ad7779_u16.
The address and data is as expected even at the ports of the FPGA. I have no clue why the variable
does not contain the expected data.
Best regards in advance
Christof
Pablo_Ramos
Hi @ChristofAbt,
I'm not able to see the peripherals.c file you mentioned.
Could you please share the configuration you are using for the FlexBus?
Pablo
ChristofAbt
Here is the flexbus configuration
* BE CAREFUL MODIFYING THIS COMMENT - IT IS YAML SETTINGS FOR TOOLS **********/
/* clang-format on */
flexbus_config_t FB_Device0_config = {
.chip = 0,
.chipBaseAddress = 0x60000000UL,
.chipBaseAddressMask = 0x0000U,
.byteEnableMode = false,
.autoAcknowledge = true,
.extendTransferAddress = false,
.byteLaneShift = kFLEXBUS_Shifted,
.portSize = kFLEXBUS_2Bytes,
.writeAddressHold = kFLEXBUS_Hold1Cycle,
.readAddressHold = kFLEXBUS_Hold1Or0Cycles,
.addressSetup = kFLEXBUS_FirstRisingEdge,
.waitStates = 0U,
.secondaryWaitStatesEnable = false,
.secondaryWaitStates = 0U,
.burstWrite = false,
.burstRead = false,
.writeProtect = false,
.group1MultiplexControl = kFLEXBUS_MultiplexGroup1_FB_ALE,
.group2MultiplexControl = kFLEXBUS_MultiplexGroup2_FB_CS4,
.group3MultiplexControl = kFLEXBUS_MultiplexGroup3_FB_CS5,
.group4MultiplexControl = kFLEXBUS_MultiplexGroup4_FB_TBST,
.group5MultiplexControl = kFLEXBUS_MultiplexGroup5_FB_TA
Pablo_Ramos
Hi @ChristofAbt,
Could you help me with the following questions?
When you mention that lsb_ad7779_u16 does not contain the expected data, what data does the variable currently hold?
How is the configuration of the pins being done?
Pablo
ChristofAbt
Hello Pablo,
the register contains random data. I can implement a kind of logic analyzer inside the FPGA and see correct data there. The flexbus pins are configured like that.
Christof
Pablo_Ramos
Hi @ChristofAbt,
Thanks for sharing the settings.
When you mention that the register contains random data, does it change with every execution?
Are you able to read the bus using an oscilloscope or a logic analyzer? This would help verify the integrity of the data across the bus.
Pablo
%3CLINGO-SUB%20id%3D%22lingo-sub-2249560%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EProblems%20reading%20Data%20from%20an%20FPGA%20via%20Flexbus%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249560%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGood%20afternoon%20community%2C%20I%20try%20to%20read%20dta%20from%20an%20FPGA%20via%20the%20NXP%20Flexbus.%20The%20microcontroller%20is%20a%20MK66FN2M0VMD18.%20Address%20and%20Data%20are%20multiplexed%20on%20a%2016bit%20bidirectional%20bus.%20The%20configuration%20is%26nbsp%3B%20defined%20in%26nbsp%3B%3CSPAN%3EFB_Device0_config.%20The%20definition%20can%20be%20seen%20in%20the%20attached%20file%20peripherals.c%20I%20%3C%2FSPAN%3E%3CSPAN%3Eincluded%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ewait%20states%20there%20but%20to%20no%20avail.%20The%20C-Code%20I%20want%20to%20read%20the%20data%20looks%20like%20that.%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3Elsb_ad7779_u16%20%3D%20*(volatile%20uint16_t*)(fb_base-%26gt%3BCS%5B0%5D.CSAR%20%2B129)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EIt%20is%20a%20read%20access%20to%20address%200d129%20%3D%200x81.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EI%20can%20observe%20the%20data%20inside%20the%20FPGA%20with%20an%20internal%20logic%20analyzer.%20The%20Address%2C%20data%20and%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Econtrol%20signals%20are%20as%20expected%20for%20a%20flexbus%20read%20access.%20Unfortunately%20I%20do%20not%20see%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ethe%20correct%20data%20in%20lsb_ad7779_u16.%20%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ChristofAbt_0-1764163846867.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ChristofAbt_0-1764163846867.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ChristofAbt_0-1764163846867.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ChristofAbt_0-1764163846867.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ChristofAbt_0-1764163846867.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367415i51B09A246103CFE2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22ChristofAbt_0-1764163846867.png%22%20alt%3D%22ChristofAbt_0-1764163846867.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CP%3EThe%20address%20and%20data%20is%20as%20expected%20even%20at%20the%20ports%20of%20the%20FPGA.%20I%20have%20no%20clue%20why%20the%20variable%3C%2FP%3E%3CP%3Edoes%20not%20contain%20the%20expected%20data.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBest%20regards%20in%20advance%3C%2FP%3E%3CP%3EChristof%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2249682%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problems%20reading%20Data%20from%20an%20FPGA%20via%20Flexbus%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249682%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248592%22%20target%3D%22_blank%22%3E%40ChristofAbt%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EI'm%20not%20able%20to%20see%20the%20peripherals.c%20file%20you%20mentioned.%3C%2FP%3E%0A%3CP%3ECould%20you%20please%20share%20the%20configuration%20you%20are%20using%20for%20the%20FlexBus%3F%3C%2FP%3E%0A%3CP%3EBest%20Regards%2C%3C%2FP%3E%0A%3CP%3EPablo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2254559%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problems%20reading%20Data%20from%20an%20FPGA%20via%20Flexbus%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2254559%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248592%22%20target%3D%22_blank%22%3E%40ChristofAbt%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3ECould%20you%20help%20me%20with%20the%20following%20questions%3F%3C%2FP%3E%0A%3CP%3EWhen%20you%20mention%20that%20lsb_ad7779_u16%20does%20not%20contain%20the%20expected%20data%2C%20what%20data%20does%20the%20variable%20currently%20hold%3F%3C%2FP%3E%0A%3CP%3EHow%20is%20the%20configuration%20of%20the%20pins%20being%20done%3F%3C%2FP%3E%0A%3CP%3EBest%20Regards%2C%3C%2FP%3E%0A%3CP%3EPablo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2257138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problems%20reading%20Data%20from%20an%20FPGA%20via%20Flexbus%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2257138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Pablo%2C%3C%2FP%3E%3CP%3Ethe%20register%20contains%20random%20data.%20I%20can%20implement%20a%20kind%20of%20logic%20analyzer%20inside%20the%20FPGA%20and%20see%20correct%20data%20there.%20The%20flexbus%20pins%20are%20configured%20like%20that.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ChristofAbt_0-1765191008313.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ChristofAbt_0-1765191008313.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ChristofAbt_0-1765191008313.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368965iE0A60AFFA4225134%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22ChristofAbt_0-1765191008313.png%22%20alt%3D%22ChristofAbt_0-1765191008313.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EBest%20regards%3C%2FP%3E%3CP%3EChristof%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2257435%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problems%20reading%20Data%20from%20an%20FPGA%20via%20Flexbus%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2257435%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248592%22%20target%3D%22_blank%22%3E%40ChristofAbt%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EThanks%20for%20sharing%20the%20settings.%3C%2FP%3E%0A%3CP%3EWhen%20you%20mention%20that%20the%20register%20contains%20random%20data%2C%20does%20it%20change%20with%20every%20execution%3F%3C%2FP%3E%0A%3CP%3EAre%20you%20able%20to%20read%20the%20bus%20using%20an%20oscilloscope%20or%20a%20logic%20analyzer%3F%20This%20would%20help%20verify%20the%20integrity%20of%20the%20data%20across%20the%20bus.%3C%2FP%3E%0A%3CP%3EBest%20Regards%2C%3CBR%20%2F%3EPablo%3C%2FP%3E%3C%2FLINGO-BODY%3E
