Problem with defining external 32K oscillator as FLL source
2,980 次查看
MichaelDavid
I have a problem with configuring 32K as clock soure.. Attached is the configuration code.
    MCG_C2 = 0;        //new        MCG_C2 = MCG_C2_HGO_MASK | MCG_C2_EREFS_MASK;        //new    MCG_C1 = 0;        //new    /* Wait for crystal to initialize */    while (!(MCG_S & MCG_S_OSCINIT_MASK)) {};        /* Wait for Reference Clock Status bit to clear */    while (MCG_S & MCG_S_IREFST_MASK) {};        /* Wait for clock status bits to show clock source      * is external reference clock */    //while (((MCG_S & MCG_S_CLKST_MASK) >> MCG_S_CLKST_SHIFT) != 0x2) {};    //new    while (((MCG_S & MCG_S_CLKST_MASK) >> MCG_S_CLKST_SHIFT) != 0x0) {};        //new FEE    MCG_C4 |= MCG_C4_DMX32_MASK | MCG_C4_DRST_DRS(3);    /* Now in FBE     * Configure PLL Reference Divider, PLLCLKEN = 0, PLLSTEN = 0, PRDIV = 0x18     * The crystal frequency is used to select the PRDIV value.      * Only even frequency crystals are supported     * that will produce a 2MHz reference clock to the PLL.     */    //MCG_C5 = MCG_C5_PRDIV(BSP_REF_CLOCK_DIV - 1);    /* Ensure MCG_C6 is at the reset default of 0. LOLIE disabled,      * PLL disabled, clock monitor disabled, PLL VCO divider is clear     */    MCG_C6 = 0;        /* Calculate mask for System Clock Divider Register 1 SIM_CLKDIV1 */    SIM_CLKDIV1_COPY =  SIM_CLKDIV1_OUTDIV1(BSP_CORE_DIV    - 1) |                        SIM_CLKDIV1_OUTDIV2(BSP_BUS_DIV     - 1) |                        SIM_CLKDIV1_OUTDIV3(BSP_FLEXBUS_DIV - 1) |                        SIM_CLKDIV1_OUTDIV4(BSP_FLASH_DIV   - 1);
2,590 次查看
tr9
In the SIM module there is a register; SIM_SOPT2 that contains the field; MCGCLKSEL that allows you to map the RTS oscillator (EXTAL32 and XTAL32 inputs) to the FLL. You set this field = 1.
From there you can use FEE mode to generate higher clock rates out of the FLL.
5 回复数
72 次查看
HANDE2910
Feeling lonely? Break the silence and connect with the world instantly! Try Omegle chat to meet new, interesting people from across the globe and spark spontaneous conversations anytime.
73 次查看
HANDE2910
Feeling lonely? Break the silence and connect with the world instantly! Try Omegle chat to meet new, interesting people from across the globe and spark spontaneous conversations anytime. https://omeglechat.love/
2,590 次查看
tr9
1. Is your external 32 K oscillator connected to EXTAL  or  EXTAL32 / XTAL32 (the RTC oscillator) ?
2,590 次查看
MichaelDavid
That was the fault. can I configure the RTC clock as the system clock?
2,590 次查看
tr9
%3CLINGO-SUB%20id%3D%22lingo-sub-187535%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%B0%86%E5%A4%96%E9%83%A8%2032K%20%E6%8C%AF%E8%8D%A1%E5%99%A8%E5%AE%9A%E4%B9%89%E4%B8%BA%20FLL%20%E6%BA%90%E6%97%B6%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-187535%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E9%85%8D%E7%BD%AE32K%E4%BD%9C%E4%B8%BA%E6%97%B6%E9%92%9F%E6%BA%90%E6%97%B6%E9%81%87%E5%88%B0%E9%97%AE%E9%A2%98%E2%80%A6%E2%80%A6%E9%85%8D%E7%BD%AE%E4%BB%A3%E7%A0%81%E9%99%84%E5%9C%A8%E5%90%8E%E9%9D%A2%E3%80%82%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%20%20%20%20MCG_C2%20%3D%200%3B%20%20%20%20%20%20%20%20%2F%2Fnew%20%20%20%20%20%20%20%20MCG_C2%20%3D%20MCG_C2_HGO_MASK%20%7C%20MCG_C2_EREFS_MASK%3B%20%20%20%20%20%20%20%20%2F%2Fnew%20%20%20%20MCG_C1%20%3D%200%3B%20%20%20%20%20%20%20%20%2F%2Fnew%20%20%20%20%2F*%20Wait%20for%20crystal%20to%20initialize%20*%2F%20%20%20%20while%20(!(MCG_S%20%26amp%3B%20MCG_S_OSCINIT_MASK))%20%7B%7D%3B%20%20%20%20%20%20%20%20%2F*%20Wait%20for%20Reference%20Clock%20Status%20bit%20to%20clear%20*%2F%20%20%20%20while%20(MCG_S%20%26amp%3B%20MCG_S_IREFST_MASK)%20%7B%7D%3B%20%20%20%20%20%20%20%20%2F*%20Wait%20for%20clock%20status%20bits%20to%20show%20clock%20source%20%20%20%20%20%20*%20is%20external%20reference%20clock%20*%2F%20%20%20%20%2F%2Fwhile%20(((MCG_S%20%26amp%3B%20MCG_S_CLKST_MASK)%20%26gt%3B%26gt%3B%20MCG_S_CLKST_SHIFT)%20!%3D%200x2)%20%7B%7D%3B%20%20%20%20%2F%2Fnew%20%20%20%20while%20(((MCG_S%20%26amp%3B%20MCG_S_CLKST_MASK)%20%26gt%3B%26gt%3B%20MCG_S_CLKST_SHIFT)%20!%3D%200x0)%20%7B%7D%3B%20%20%20%20%20%20%20%20%2F%2Fnew%20FEE%20%20%20%20MCG_C4%20%7C%3D%20MCG_C4_DMX32_MASK%20%7C%20MCG_C4_DRST_DRS(3)%3B%20%20%20%20%2F*%20Now%20in%20FBE%20%20%20%20%20*%20Configure%20PLL%20Reference%20Divider%2C%20PLLCLKEN%20%3D%200%2C%20PLLSTEN%20%3D%200%2C%20PRDIV%20%3D%200x18%20%20%20%20%20*%20The%20crystal%20frequency%20is%20used%20to%20select%20the%20PRDIV%20value.%20%20%20%20%20%20*%20Only%20even%20frequency%20crystals%20are%20supported%20%20%20%20%20*%20that%20will%20produce%20a%202MHz%20reference%20clock%20to%20the%20PLL.%20%20%20%20%20*%2F%20%20%20%20%2F%2FMCG_C5%20%3D%20MCG_C5_PRDIV(BSP_REF_CLOCK_DIV%20-%201)%3B%20%20%20%20%2F*%20Ensure%20MCG_C6%20is%20at%20the%20reset%20default%20of%200.%20LOLIE%20disabled%2C%20%20%20%20%20%20*%20PLL%20disabled%2C%20clock%20monitor%20disabled%2C%20PLL%20VCO%20divider%20is%20clear%20%20%20%20%20*%2F%20%20%20%20MCG_C6%20%3D%200%3B%20%20%20%20%20%20%20%20%2F*%20Calculate%20mask%20for%20System%20Clock%20Divider%20Register%201%20SIM_CLKDIV1%20*%2F%20%20%20%20SIM_CLKDIV1_COPY%20%3D%20%20SIM_CLKDIV1_OUTDIV1(BSP_CORE_DIV%20%20%20%20-%201)%20%7C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20SIM_CLKDIV1_OUTDIV2(BSP_BUS_DIV%20%20%20%20%20-%201)%20%7C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20SIM_CLKDIV1_OUTDIV3(BSP_FLEXBUS_DIV%20-%201)%20%7C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20SIM_CLKDIV1_OUTDIV4(BSP_FLASH_DIV%20%20%20-%201)%3B%20%20%20%20%20%20%20%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2425725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problem%20with%20defining%20external%2032K%20oscillator%20as%20FLL%20source%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2425725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E5%88%B0%E5%AD%A4%E7%8B%AC%E5%90%97%EF%BC%9F%E6%89%93%E7%A0%B4%E6%B2%89%E9%BB%98%EF%BC%8C%E7%9E%AC%E9%97%B4%E4%B8%8E%E4%B8%96%E7%95%8C%E8%BF%9E%E6%8E%A5%EF%BC%81%E8%AF%95%E8%AF%95%3CA%20title%3D%22Omegle%22%20href%3D%22https%3A%2F%2Fomeglechat.love%2F%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EOmegle%20%E8%81%8A%E5%A4%A9%3C%2FA%3E%EF%BC%8C%E7%BB%93%E8%AF%86%E6%9D%A5%E8%87%AA%E4%B8%96%E7%95%8C%E5%90%84%E5%9C%B0%E7%9A%84%E6%96%B0%E6%9C%8B%E5%8F%8B%EF%BC%8C%E9%9A%8F%E6%97%B6%E9%9A%8F%E5%9C%B0%E5%BC%80%E5%90%AF%E5%8D%B3%E5%85%B4%E5%AF%B9%E8%AF%9D%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2425723%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problem%20with%20defining%20external%2032K%20oscillator%20as%20FLL%20source%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2425723%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%84%9F%E5%88%B0%E5%AD%A4%E7%8B%AC%E5%90%97%EF%BC%9F%E6%89%93%E7%A0%B4%E6%B2%89%E9%BB%98%EF%BC%8C%E7%9E%AC%E9%97%B4%E4%B8%8E%E4%B8%96%E7%95%8C%E8%BF%9E%E6%8E%A5%EF%BC%81%E8%AF%95%E8%AF%95%20Omegle%20%E8%81%8A%E5%A4%A9%EF%BC%8C%E7%BB%93%E8%AF%86%E6%9D%A5%E8%87%AA%E4%B8%96%E7%95%8C%E5%90%84%E5%9C%B0%E7%9A%84%E6%96%B0%E6%9C%8B%E5%8F%8B%EF%BC%8C%E9%9A%8F%E6%97%B6%E9%9A%8F%E5%9C%B0%E5%BC%80%E5%90%AF%E5%8D%B3%E5%85%B4%E5%AF%B9%E8%AF%9D%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fomeglechat.love%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fomeglechat.love%2F%3C%2FA%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-187538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problem%20with%20defining%20external%2032K%20oscillator%20as%20FLL%20source%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-187538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9C%A8%20SIM%20%E6%A8%A1%E5%9D%97%E4%B8%AD%E6%9C%89%E4%B8%80%E4%B8%AA%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%9BSIM_SOPT2%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%8C%85%E5%90%AB%E5%AD%97%E6%AE%B5%EF%BC%9BMCGCLKSEL%EF%BC%8C%E5%85%81%E8%AE%B8%E6%82%A8%E5%B0%86%20RTS%20%E6%8C%AF%E8%8D%A1%E5%99%A8%EF%BC%88EXTAL32%20%E5%92%8C%20XTAL32%20%E8%BE%93%E5%85%A5%EF%BC%89%E6%98%A0%E5%B0%84%E5%88%B0%20FLL%E3%80%82%E6%82%A8%E5%B7%B2%E5%B0%86%E6%AD%A4%E5%AD%97%E6%AE%B5%E8%AE%BE%E7%BD%AE%E4%B8%BA%201%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BB%8E%E9%82%A3%E9%87%8C%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20FEE%20%E6%A8%A1%E5%BC%8F%E6%9D%A5%E4%BA%A7%E7%94%9F%E6%9B%B4%E9%AB%98%E7%9A%84%20FLL%20%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-187537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problem%20with%20defining%20external%2032K%20oscillator%20as%20FLL%20source%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-187537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%82%A3%E5%B0%B1%E6%98%AF%E7%BD%AA%E9%AD%81%E7%A5%B8%E9%A6%96%E3%80%82%E6%88%91%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%AE%9E%E6%97%B6%E6%97%B6%E9%92%9F%20(RTC)%20%E9%85%8D%E7%BD%AE%E4%B8%BA%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%92%9F%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-187536%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problem%20with%20defining%20external%2032K%20oscillator%20as%20FLL%20source%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-187536%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E1.%20%E6%82%A8%E7%9A%84%E5%A4%96%E9%83%A8%2032K%20%E6%8C%AF%E8%8D%A1%E5%99%A8%E6%98%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%20EXTAL%20%E8%BF%98%E6%98%AF%20EXTAL32%20%2F%20XTAL32%EF%BC%88RTC%20%E6%8C%AF%E8%8D%A1%E5%99%A8%EF%BC%89%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
