Problem with AN2295SW bootloader on Kinetis K40
1,640件の閲覧回数
janbrázdil
Hello guys.
I'm trying AN2295SW bootloader on Kinetis K40 CPU. I tried few different versions of AN2295SW, but only one version contains project for CodeWarrior. I have CodeWarrior 10.3, and project inside AN2295SW folder is for 10.2. But i make this project functional with few modifications.
When i start win_hc08sprg.exe and hit connect, everythink is okay. But last message is:
WARNING! S19 image will not fit into available memory (at address 0x00000800)!
I think, that i have few mistakes in linker, or in config file (Because CPUhas 256kB memory). But i can't fix it. I read manual and guide and still don't know what to do...
Is there anyone who make functional AN2295SW bootloader on Kinetis K40?
I will be glad for every advice, thanks.
Best Regards, Fbi.
1,242件の閲覧回数
pavel_krenek
Could you try to be more specific about the your application and S19 file ? I mean placing of the application in memory in linker file ?
Pavel Krenek
AN2295 Developer
