PTA2/PTA3 as GPIO Output on KEA128
zhangzhongjun
The chip is powered by 3.3V, so the pins are connected to a 3.3V 4.7K resistor for pull-up output. You can observe the changes in the value of the GPIOA_PDOR register. However, using a multimeter, we cannot measure the changes in the high and low levels of PTA3. Have I overlooked any configuration?
FRDM-KEAZ128
carlos_o
Hi @zhangzhongjun
Thanks for your post.
I'm understanding that you have problems when you try to toggle one pin at Port A. Am I understating correctly?  Could you share more details about your issue please?
%3CLINGO-SUB%20id%3D%22lingo-sub-2175406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPTA2%2FPTA3%20as%20GPIO%20Output%20on%20KEA128%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20chip%20is%20powered%20by%203.3V%2C%20so%20the%20pins%20are%20connected%20to%20a%203.3V%204.7K%20resistor%20for%20pull-up%20output.%20You%20can%20observe%20the%20changes%20in%20the%20value%20of%20the%20GPIOA_PDOR%20register.%20However%2C%20using%20a%20multimeter%2C%20we%20cannot%20measure%20the%20changes%20in%20the%20high%20and%20low%20levels%20of%20%3CSTRONG%3EPTA3%3C%2FSTRONG%3E.%20Have%20I%20overlooked%20any%20configuration%3F%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FFRDM-KEAZ128%2Fpd-p%2FFRDM-KEAZ128%22%20class%3D%22lia-product-mention%22%20data-product%3D%222731-1%22%20target%3D%22_blank%22%3EFRDM-KEAZ128%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%3EThanks%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2175406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EKinetis%20EA%20Series%20MCUs%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2177632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PTA2%2FPTA3%20as%20GPIO%20Output%20on%20KEA128%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177632%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202124%22%20target%3D%22_blank%22%3E%40zhangzhongjun%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20post.%3C%2FP%3E%0A%3CP%3EI'm%20understanding%20that%20you%20have%20problems%20when%20you%20try%20to%20toggle%20one%20pin%20at%20Port%20A.%20Am%20I%20understating%20correctly%3F%26nbsp%3B%20Could%20you%20share%20more%20details%20about%20your%20issue%20please%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
