PLL configuration for MK60FN1M0VLQ12
vanajagujjala
     This is vanaja.I created PE code for MK60FN1M0VLQ12 and set the PLL clock and every clock,I just checked FB_CLK(FB_CLKOUT) It shows 10MHZ only but I set to 40MHZ,If I make any changes no response it is same 10MHZ only.
Is there any sample PE code for K60-120MHZ processor.
BlackNight
