OpenSDA
madisonchou
Hi, I am trying to use the OpenSDA on FRDM-K20D50M to debug our board that has K20DX128VLK7.  So far, I have no luck.  Our board can be connected to and be debugged in CW using PEMicro's Multilink.  So, the JTAG on our board is verified.   I cut the trace on FRDM's J11.  But the FRDM's openSDA LED blinks when connects to our board.   Any suggestion??
madisonchou
Hi Erich,
Thanks you very much for the information.   Sorry for the late reply.   I was side-tracked to other more urgent stuff.
I am now has a KL25 FRDM board on hand.  Will try it.
BlackNight
you cannot debug another board with the P&E OpenSDA firmware: you need either CMSIS-DAP, USBDM or Segger.
I have not used the FRDM-K20 for this, but others like the FRDM-KL25Z or FRDM
There are a series of articles which should help you:
madisonchou
Hi Erich,
