Open SDA 10 pin Header
ソリューションへジャンプ
2,524件の閲覧回数
galadragos
The Freedom Board has two 10 pin headers for off-board targets. Those headers are 1.27mm spaced and dual row.
I am having difficulty (as in extreme difficulty) in finding any female header connector that can fit these. Can someone provide a link to a vendor that carry these?
I live in Europe so I cannot order from DigiKey because of cost issues.
Thanks.
2,180件の閲覧回数
galadragos
And because I like to answer to my own questions, I've managed to find the connectors:
this is for the ribbon cable:
http://ro.farnell.com/jsp/search/productdetail.jsp?sku=1392944
this is for the pcb
http://ro.farnell.com/jsp/search/productdetail.jsp?sku=1577743
and a smd version (for the kwikstik):
http://ro.farnell.com/jsp/search/productdetail.jsp?sku=1022310
I will order them and see if they fit.
2 返答(返信)
2,180件の閲覧回数
galadragos
this is for the pcb
2,180件の閲覧回数
GregC
Hello
I just requested a sample cable SAMTEC p/n FFSD-05-D-06.00-01-N on their website to check the compatibility with the JTAG connector from FRDM.
I choosed the reference based on following doc (and with the help of my colleagues) but I agree with you, choose a connector is quite complicated :smileysad:
http://www.samtec.com/ftppub/pdf/ffsd.pdf
