Methods of capuring PWM duty coupled with Processor Expert
981 次查看
rolandchok
Hello Guys,
     i just want some ideas on how do you capture duty cycle of a PWM signal. anyone has implemented it using the capture bean in processor expert or just watch the Pin as is go high to low, enabling the timer during signal high and stopping it when it goes low.
what method do you think is the most efficient way of doing this especially when try to capture multi channel
thank you
regards,
Roland
0 回复数
