MKV58F1 HSADC missing values
1,296 次查看
michaelus84
I have a problem with HSADC on MKV58F1. For values ​​between 2047 and 2053, there is a sort of dead zone. I can't get intermediate values ​​of just 2047 and less or 2053 and more.
The problem occurs with both HSADC modules.
1 回复
1,278 次查看
Omar_Anguiano
Hello michaelus84
Thank you for your interest in NXP Semiconductor products and the opportunity to serve you. My name is Omar and I will gladly help you with this.
It could be helpful if you share in detail the configuration of the HSADC. You can use one of the SDK examples to see if this issue persists.
I will be waiting for your reply, if you have more questions do not hesitate to ask me.
Omar
