MKV56F512VLL24  / MKV56F512VLL24557
1,487 次查看
amerzater
Hello Everybody
when I was looking for a distributor of  MKV56F512VLL24  I found this uC (MKV56F512VLL24557)
it says that the manufacturer is Rochester Electronics ..is it the same uC chip of MKV56F512VLL24  ?
标签 (1)
标记 (1)
1 回复
1,470 次查看
kerryzhou
Hi amerzater,
MKV56F512VLL24 NXP link is:
https://www.nxp.com/products/processors-and-microcontrollers/arm-microcontrollers/general-purpose-mc...
So, you need to double check with your mentioned distributor , let they provide the above link chip.
Wish it helps you!
kerry
