MKL15Z32VFM4 & keil
MKL15Z32VFM4 & keil
chenxikean
I want to know where can I get this model: MKL15Z32VFM4 About using keil to develop a routine?
kerryzhou
Hi chenxikean,
   Do you mean mdk MKL15Z32VFM4  DFP?
  If yes, please download this dfp from the keil side, and install it, you will find the related chip:
https://www.keil.com/dd2/pack/#/third-party-download-dialog
under keil item, you will find the KLXX series:
Download it and install it.
You will find it in your MDK:
Wish it helps you!
If you still have questions about it,please kindly let me know.
Kerry
chenxikean
Hello, I got this DFP package, but I want a keil routine.
kerryzhou
Hi chenxikean,
   I am not very clear about your mentioned keil routine, example code?
   If not, maybe you need to check with keil side:
  https://www.keil.com/support/
  Normally, we provide the kinetis example code, and other IDE details, you may need to check the IDE side.
Wish it helps you!
Kerry
chenxikean
Yes, I want the example code for this model (MKL15Z32VFM4).
kerryzhou
Hi chenxikean,
  MKL15Z32VFM4  code can be downloaded from this link:
https://mcuxpresso.nxp.com/en/select
Generate the code, and download it, you will find the code.
Please note, the default examples is for MKL25, so you can replace all the example project driver in the SDK package->device.
Wish it helps you!
Kerry
