MKE14F: TRGMUX complain
1,281 次查看
michaelheidinge
The TRGMUX is a really good advantage for programming MCUs. But why the heck only 23 channels out of 128 are assigned? Why are not all channels routed to the trgmux? Example Uart communication error.
The idea is really good, but implementation could be advanced.
1,162 次查看
Hui_Ma
Thank you for the feedback.
About using UART communication error as trigger source, I think that still need be discussed. When UART communication with error, the better handle way to generate a UART interrupt to handle related error issue.
Thank you for the attention.
Ma Hui
