MK82 SD Card driver
MK82 SD Card driver
1,599件の閲覧回数
WilhelmT
we have a board with MK82FN256VLL15 and a SD card slot and I need to write a software to control the SD card.
In the SDK for the MK82 controller there are unfortunately no sample projects with the SD card.
The question:
1) are there sample projects for other controllers that are compatible with MK82?
2) What other options do I have to achieve my goal quickly?
Thanks in advance.
ラベル(2)
1,568件の閲覧回数
RaRo
Hello @WilhelmT;
There are not such examples that works with the SD Card. Nevertheless, you could download the SDK package and look into the "drivers" folder. There, you can find both "fsl_sdhc.c" and "fsl_sdhc.h", here you may find example functions, for your implementation.
Please check the User Manual: Chapter 62. Secured digital host controller (SDHC) too, for more information.
Best regards, Raul
