MK64 +fatfs+emmc ,save data on time(20HZ)
OneByte
I have a problem ,After storing data for a period of time(Time is not fixed), the task is suspended,Positioning is always waiting for the event completion flag position bit,SDMMC_OSAEventWait();
Pavel_Hernandez
I recommend reviewing the example in the SDK.
Pavel
Pavel_Hernandez
Pavel
OneByte
thanks , what should I pay attention to when changing from sd storage to emmc storage? I just changed the corresponding driver file and found it was not working.
OneByte
just change fsl_sd.c->fsl_mmc.c and
fsl_sd_disk.c->fsl_mmc_disk.c
