MK22FN1M0vlh12 memory
2,463件の閲覧回数
geison_mancuzo
i need write and read data of configuration im memory the product in development. This micro don't have EEPROM, how should I do ? help me.
tks. Geison
4 返答(返信)
2,357件の閲覧回数
kerryzhou
Hi Geison Mancuzo,
    Yes, MK22FN1M0VLH12 don't have EERROM, so if you want to store the data, you can store it in the flash sector, eg, you use the last flash sector as your user area.
    One sector = 2KB size.
    But take care, flash is not EEPROM, when you want to modify it, you should erase the sector and program it again.
    About the flash operation sample code, you can refer to the FRDM-K22 ksdk sample code:
www.nxp.com/ksdk
Wish it helps you!
If you still have question, please contact me!
Jingjing
2,357件の閲覧回数
geison_mancuzo
Thank you so much for your answer, but dont find examples do not know how do.
att.
2,357件の閲覧回数
kerryzhou
Hi Geison,
    If your question is solved, could you help me to close this question by clicking the Correct answer button?
   Thank you very much and have a nice day!
Jingjing
2,357件の閲覧回数
kerryzhou
Hi Geison,
    Go to this link, and login:
Welcome to Kinetis Expert | Kinetis Expert
click Build an SDK, choose boards, FRDM-K22, then build SDK package:
click software vaults, and download the SDK_2.0_frdm-k22f, you will find the flash sample code in folder:SDK_2.0_FRDM-K22F\boards\frdmk22f\driver_examples\flash\flash_erase_program_verify
Wish it helps you!
Jingjing
