MK10DX256VLH7 KDS J-Link debugging Could not connect to target
hwqconcept
I use j-link debugging MK10DX256VLH7 in KDS.Prompt error"Could not connect to target. Please check if target is powered and if ribbon" .How to solve it?
ErichStyger
Specialist I
Did you check that
a) your target board is powered
b) you plugged in the SWD cable with the correct orientation
Otherwise, this checklist can help:
https://mcuoneclipse.com/2014/11/03/debugging-failure-check-list-and-hints/
Erich
