LinkFlash tool
LinkFlash tool
AndreVB
Hello Comumnity !
I am using the MKL17Z64 in my application. I would like to use the LinkFlash tool (v25.6.131) to program my boards, but the MKL17Z64 does not appear in the device list.
Is there a workaround or an equivalent device selection I could use?
Thank you!
Andre
Hello @AndreVB
Please refer to the below blog to change a JSON file: Using Legacy Devices with LinkServer | MCU on Eclipse
Alice
Hi @AndreVB
Thanks for your question. LinkFlash does not currently support this chip. I will check with our internal team to see if there is a JSON file available that supports this device.
Thank you.
Alice
