LCD via Flexbus for k70
1,774件の閲覧回数
ankurchauhan
I'm trying to use Twr-LCD Module via flexbus interface using  k70 bareboard project.
can anyone share some sample code and datasheets for this.
Ankur
3 返答(返信)
1,600件の閲覧回数
adriancano
Hi Ankur Chauhan,
You will probably find useful this post:
FlexBus in 16 bit mode and 8 bit access
Adrian
1,600件の閲覧回数
ankurchauhan
Thanks Adrian..
1,600件の閲覧回数
ankurchauhan
Hi Adrian:
As per the sample code given in the link, they are sending some command to some particular address (i.e some hex values like 0x004f to address 0x60000000 address is always fix but values varying ) can u explain me whats those command are doing.
Ankur
