LCD display K60 family
2,027 次查看
wilk
Hi I am using the Kinetis MK60DN256ZVLL10 (k60 Family) and I want to add an external LCD display.
Is it possible to control the LCD using the Freescale eGUI (I want to use the Freescale MQX RTOS btw) ?
Thanks ! :smileyhappy:
标记 (3)
1,795 次查看
wilk
Problem solved, it's not possible :smileycry:
1,795 次查看
LuisCasado
It is possible to connect an smart display as we do with TWR-K60 + TWR-LCD. You can't connect an standard TFT, you would need a K70 for that. But in many cases an smart display connected to Flex bus is a good solution.
Luis
