Kwikstik schematic and pinout
2,781件の閲覧回数
mareklagger
I want to use kwikstik for robotic project and I am confused of freescale solutions. Finally I have found MCU  K40 144 LQFP pinout but cant figure out how are the pins connected to PCIE x164 connector. The kwikstik manual connector pinout table says something about names: IRQ, PWM... How can I know how are these (pin names?) connected to MCU pins? Is there any schematic that explains it?
If I understood that correctly PCIE x164 connector doesnt have many pins connected to MCU pins. Iam right?
Thank You.
Marek
2 返答(返信)
2,174件の閲覧回数
tom_thompson
Go to this Freescale web page for information on the Kwikstik product. Under the Current Releases and Updates section you will find the entry KWIKSTIK-K40-SCH_V4, which is a link to the version 4 schematics. Hope this helps.
---Tom
2,174件の閲覧回数
mareklagger
Thank you. I thought it could be under documentation. Didnt saw it there somehow
But its dissapointing that on a expensive PCIE x164 connector are only few pinouts.
