Kwikstik Demo Lab for MQX not working weird problem
已解决
跳至解决方案
2,188 次查看
nabeelkhan
I am using K40X256VLQ100, Downloaded the Demo for MQX and trying it running over MQX 3.7 under Code Warrior 10.1 environment. I have successfully Built the kwitstik demo and more over can easily RUN and Debug it over software without error . But still the demo is not showing on the board or have not able to see anything on my SLCD . software is doing debugging and running what ever i want to do. but nothing take place over the board .however I have to connect the J-link while doing debug or Run otherwise it come up with error as it should do. so don't know where i am going wrong Please help me out
标签 (1)
标记 (4)
1 解答
2,072 次查看
nabeelkhan
i solved it ... The target task was not correctly selected
在原帖中查看解决方案
1 回复
2,073 次查看
nabeelkhan
