Kinetis assembler instructions
pvidic
Hi, examining Kinetis bootloader source code I found assembler instruction below:
file cmsis_gcc.h:
__attribute__( ( always_inline ) ) __STATIC_INLINE void __disable_irq(void)
  __ASM volatile ("cpsid i" : : : "memory");
can anyone help me find explanation for the instruction?
BlackNight
"cpsid i" is an assembly instruction to mask (disable) the interrupts on ARM Cortex-M.
About the GNU assembler have a read at
Using as: Top and there is a tuturial and good explanation at ARM GCC Inline Assembler Cookbook
I hope this helps,
Erich
