Kinetis USB Host and Device SDK Example
3,927件の閲覧回数
Keith4DSmith
Contributor V
Are there any Kinetis K series SDK examples that have both a USB host and a USB device in the same example?
ラベル(2)
5 返答(返信)
3,159件の閲覧回数
danielchen
Hi Keith
Please download sdk for frdm-k66 from nxp website.
Welcome | MCUXpresso SDK Builder
unzip the package, there are two demos for your requirement.
FRDM-K66F_2.4.0_0605\boards\frdmk66f\usb_examples\usb_pin_detect_hid_msd\freertos
when you connect k66 with your PC,  k66 work as a msd device.
when you connect a mouse with K66, it will act as  a hid host
Please also refer to this demo,
FRDM-K66F_2.4.0_0605\boards\frdmk66f\usb_examples\usb_pin_detect_hid_mouse\freertos
3,159件の閲覧回数
Keith4DSmith
Contributor V
Daniel - The example you mentioned appears to be an example of how to support OTG. Is there an example of using two ports, one as a device and one as a host simultaneously?
I have the requirement to be a USB host to communicate with a USB CDC device, while being connected to a PC as a USB CDC device.
3,159件の閲覧回数
danielchen
Could you please let me know which board/MCU you are using?
3,159件の閲覧回数
Keith4DSmith
Contributor V
I thought I would use the K26 MCU as it has two USB ports.
3,159件の閲覧回数
danielchen
Hi  Keith Smith :
Thank you for your additional information.
I would suggest you download the MCUXpresso SDK for TWR-K65F180M board. There is a keyboard2mouse demo.
This demo implements the host and the device, where the KHCI works as host and the EHCI works as a device.
The host supports the keyboard device and device works as a mouse when connecting to the PC. It seems very similar to your requirements.
I hope it helps.
